What gives?
Installing SolarWinds Orion Network Performance Monitor 10.1.1 SP1Error: SolarWinds Orion Network Performance Monitor 10.1.1 required. Version "10.1.4.0" found.Press any key to continue . . .
Sorry folks there is some confusion here on our part, my fault.
SP1 includes HF2, so no need to re-apply.
If you cared about HF1, which is not something which is globally applicable to everyone, then you will need to re-apply that after upgrading to SP1.
Sorry for the confusion.
Are you running 10.1.1 or just 10.1?
I bet 10.1.1-RC
Re-downloaded 10.1.1 from portal and re-installed. Fine now.
You also can't re-install Hotfix 2
I also am unable to re-apply hotfix 2 as outlined in the aboved notes:
"Attempt to downgrade Solarwinds Job Engine v2.0.3 is not allowed"
Sorry, I meant to say as outlined in the following post:
