Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Wish list for next version/update
ceclark
I just upgraded to version 3.5 and I like what I see. There are no "security" enhancements, so that is where my wish list is coming from....
1. SNMPv3 Support
2. Allow file transfers using a secure protocol like SCP. (we're not allowed to directly log into a device, however we can transfer the config via SNMPv3 using a secure protocol)
3. Separate login credentials for connecting to device and authentication to a device (see
www4.solarwinds.net/.../topic.asp
. This could be resolved with #1 and #2 being implemented
Find more posts tagged with
Accepted answers
All comments
SamuelB
I agree with all of the above, especially #3. But I would also add:
1. Option for Cirrus to automatically reschedule config download (just for individual node) if node was down when normal nightly inventory/config download job takes place.
2. Ability (or scriptable way) for Cirrus to automatically update credentials for individual device if credentials are changed using a command script.
3. As always, tighter integration with Orion including the ability to manage Cirrus via a web interface.
4. Option for parallel command script execution.
jedi755
BETTER SEARCHING!! We need to be able to search for patterns and for missing commands like in Cisco Works.
FormerMember
The ability to search the node list.
Stronger config editor, maybe with cisco syntax highlighting
Better integration with other products like Orion and Engineer's toolkit.
FormerMember
Get the Node list from the Orion database. Thus I do not have to enter devices TWICE, or forget to add them etc...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
