Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Feature Request... Backup Interfaces
skrause
It would be nice if we could flag a given interface as a "backup", meaning that it's normal state is down and up is the exception. We use Orion to monitor around 350 WAN routers, most of which have an ISDN backup circuit provisioned. Right now we have to keep a parallel system up for monitoring these since if we monitored them within Orion every device would have one perpetually down interface.
Find more posts tagged with
Accepted answers
All comments
efetty
you could use the alarm suppression feature to accomplish this.
Eric Fetty
Senior Network Administrator
Siemens
4705 Duke Drv
Mason, OH 45040
eric.fetty@sbs.siemens.com
skrause
I don't need to set up any alerts for the BRI interfaces, I just want to be able to monitor them. I don't think the alert suppression affects the "group status".
The problem is if I begin monitoring a router's BRI interface, which is normally down, then the node's group status becomes "up-down" which shows up on the web site as a big green dot with a flashing red dot in the corner indicating one of the interfaces is down. If I do that on all of the routers then all the nodes are perpetually "up-down" and I can't look at the web site any more to see which nodes are having real problems (the frame-relay interface is down) and which are normal (only the BRI is down)
Flagging an interface as "backup" would, ideally, stop that interface from being counted when computing the node's group status
-Steve
Network_Guru
Steve,
Here's a possible workaround until this feature gets implemented;
You could create a map with all normally up interfaces, using
a %100 Threshold. Any down interface would cause the map icon
to flash red.
Conversely, you could create a map with all normally down -
backup interfaces, using a %1 Threshold. If the Icon status
goes green, then you have a backup interface which is turned up.
Then just create a master map with icons of these other maps.
If you use Visio to create the map JPG/GIF you can get creative
and use boxes with descriptions for each map & drag the map icons
into these boxes. That's if you don't want to use actual drawings
or maps.
-=Cheers=-
NG
ralf.hessberger
Hello Steve,
what about to combine both: the surpression because the normal stat is down and the map feature by leaving the BRIs away ?
We did want to see a map status going to yellow or red as soon as any interface goes down, so all the interfaces are placed on the map for Germany, but in a hidden way. If you see the web page you see only the sites. You can do this by drag and drop the interfaces of all desired routers to the grey area beside your map in the map maker tool. Tey will not be visible to the customer.
hope that this may help in anyway,
Ralf
Ralf Hessberger
Administrator Network Monitoring
IT Shared Services Northern Europe
Phone: +49 5653 918 144
Mobile: +49 178 7240 440
mailto: rhessberger@stadthagen.faurecia.com
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
