Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Date/Time Exclusions
jonchill
Isn't it about time that Solarwinds made this filter part of Orion rather than us users having to install it each time we do an upgrade to a new version, it can't be that difficult to do?
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Find more posts tagged with
Accepted answers
All comments
Network_Guru
www.solarwinds.net/NoMaintOrion.htm
There must be some incentive to Purchase Maintenance...
-=Cheers=-
NG
iunderwo
Actually, having the installer be cognizant of an already-installed system would be a big plus period. Especially since redoing the report-writer schema and deleting the default reports is cumbersome.
Fortunately, upgrades don't happen all too often.
// Ian Underwood - Service Management
// Level 3 Communications
marksmink
I have installed the Report Writer DateTimeExclusions add-in according to the instruction but where do you set the exclusions when running a report? Are they SQL commands or is it part of the report wizard?
I want to be able to run a report covering only business hours.
Thanks in advance.
Mark
Cheers,
Mark
Network_Guru
Do a search for exclusions;
www2.solarwinds.net/.../topic.asp
It shows up as a separate item under the filter results tab.
"Date/Time (Availability time filtering only)"
-=Cheers=-
NG
ftsang
To use the date/time exclusions, it's pretty misleading, you DON'T goto the "time frame" tab, you have to do it from the "Filter results" tab in the report designer. Create a new "elementary condition and you'll have an option for date/Time filtering.
To get stats for between 9 AM and 5 PM you would need two date/time filter conditions which would be
Records where Time of DAY(24 hour format) is greater than 090000
Records where Time of DAY(24 hour format) is less than 170000
marksmink
Thanks, NG and ftsang, it works well!
Cheers,
Mark
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
