I need to create an activity which will execute commands on multiple devices in a specific order. How can I do that?
Mark.
Hi Mark,
Just to clarify the question, I am presuming you are referring to the specific order being in relation to the device order rather than the list of commands?
If so, then I'm afraid there isn't any way to specifically set the order in which the selected devices are connected to. If you'd like to elaborate on the requirement though, I may be able to suggest a workaround for you?
Regards,
Steve
