Is anyone using LEM for Motorola RFS6000 switches? What connector should we use. It started logging using the Cisco IOS and PIX connector but it is throwing errors because it is not a Cisco device,
The first thing I would do is make sure that the connector pack was the latest and greatest: SolarWinds Knowledge Base :: How to apply a LEM connector update package
I've looked through the latest, though, and I don't think that Motorola's switches are matched. If a connector is needed, try the following:
There is no guaranteed time frame for getting a new connector, but that would at least get you moving towards a solution.
