Does anyone have any experience using a stored procedure on their SQL server to populate a custom property on a recurring schedule?
For example, I want to create a custom property with a floating value that contains the delta of the volume space used over the past hour. I want to populate this value every 60 minutes using a stored procedure which calcluates this delta.
I have the SQL query for this and I do it outside of Orion in a static report. I would like to move it into a custom property so I can alert based on this value.
