Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Alert Dependencies
jlunsford
Hi, I'm just trying to get some confirmation.
We currently have over 50 remote offices that we monitor, plus datacenter, plus misc. Currently in our alerts we have an alert for monitoring non-critical nodes, which basically means that we just don't get paged for those during non-business hours. Then we have critical nodes that we get pages for 24x7.
We currently only get pages for node status, but I want to set it up so that we get paged fore certain interfaces and vpn tunnels. However, I'd like to setup some dependencies so that we don't get paged for the vpns if the main internet connection is down, and so that we don't get paged for any of the interfaces if the whole node is down.
From the reading that I've done, it doesn't look like I can do this with the current way our alerts are setup. It looks like I'll need to setup a seperate alert for each office, and then I can configure the alert supression/dependencies for each of the offices.
Can someone tell me if I have this right/wrong.. If I have it wrong, can someone tell me the workaround??
Thanks!!!!
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Yes you are correct, you need a separate alert for each dependency.
This has been discussed in several other posts. Do a search in this Forum for "alert suppression".
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
jlunsford
Ah thanks, will do..
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
