Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Changing Bandwidth Values
danbowen
Hi Everyone,
I use SW to monitor a lot of WAN connections, but as we do not have SNMP access to the WAN routers, we monitor the switch interface that connects to that router. As the switch interface speed is either 100 or 10mb, and the WAN speed is anything between 128kbps and 34mb, we get misleading utilization percentages.
Any idea on how you can force SW to believe that a 100mb interface is say 4mb?
Cheers,
Dan
Find more posts tagged with
Accepted answers
All comments
ceclark
You can change the bandwidth on the switchport. Be careful as changing the bandwidth statement can/will affect your routing.
ACCESS41(config)#int fa0/48
ACCESS41(config-if)#bandwidth ?
<1-10000000> Bandwidth in kilobits
iunderwo
You should be able to set an arbitrary speed on each interface in the System Manager. You can modify the transmit and receive speeds independently if need be.
// Ian Underwood - Network Engineering
// Boston Stock Exchange
larry.rice
I believe you would do this on a per interface basis. In the system manager, right click on the interface you want to edit. At the top, you have transmit and receive bandwidths you can adjust.
Does that work for you?
Larry.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
