Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Automatic Reporting Functions
mfeliciano
Hi all,
First time here. Sorry if this has been asked before but, is there a way to automate reports on a monthly basis for say, bandwidth reports?
I see you can manually export graphs to jpeg, bmp, etc. and you can export to CSV but, they are all manual. Would like to setup something similar to MRTG where bandwidth reports are published to a web server for managers to view.
I could setup a static page and do a crude ftp upload to overwrite but, wanted to see if there was a built in way.
thanks in advance
Find more posts tagged with
Accepted answers
All comments
Mart
Did you ever get an answer to this question? I want to do the same thing from the Network Performance Monitor.
Martin
Bryan
There are lots of creative things that you can do. As far as built in fuctionality, there isn't much for what your talking about. You can port your network performance monitor db over to SQL server and create some of your own custom reports. If you do this, when your SWnetperfmon.cfg Access DB gets to big, you can simply import the data to SQL before you have to rebuild. This way you will have a running archive all in one DB under SQL
Lockheed Martin
Atlas V Launch Operations
Network Engineer
senthiln
Mr.Lockheed Martin sir,
Greetings
pls, Can u tell me this works in details.
i will wait for ur golden response.
Thanks in advance
senthil
senthilkumar
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
