Does or can Orion pull CAM tables from switches?
Orion NCM (formerly Cirrus) can pull the CAM tables by default. Using Orion NPM you could probably use the Universal Device Poller to pull the CAM table via SNMP and display it in a table or something.
Do you know the OID value and switch model to create UNDP ?
Orion NPM is able to poll CAM tables from devices using SNMP. Information is stored in NodeL2Connections table in Orion Database. Orion uses this information for topology calculation. Table should be also exposed via SWIS, so you should be able to use Custom Query Resource to display the data. Available pollers for getting CAM/Bridge table information for Nodes are (both are displayed as L2 Topology pollers on List Resources):
N.Topology_Layer2.SNMP.Dot1dTpFdb
Topology poller for L2 entries gathering accross all VLANs for devices which support BRIDGE-MIB and SNMP community string based indexing. Poller utilizes GetTable request to gather Port IDs, MAC addresses and Statuses using OID:
dot1dTpFdbTable = 1.3.6.1.2.1.17.4.3
Port IDs are received from:
dot1dTpFdbPort = 1.3.6.1.2.1.17.4.3.1.2
MAC addresses are received from:
dot1dTpFdbAddress = 1.3.6.1.2.1.17.4.3.1.1
Statuses are received from:
dot1dTpFdbStatus = 1.3.6.1.2.1.17.4.3.1.3
N.Topology_Layer2.SNMP.Dot1qTpFdb
Topology poller for L2 entries gathering accross all VLANs for devices which support Q-BRIDGE-MIB and SNMP community string based indexing. Poller utilizes GetTable request to gather Port IDs, MAC addresses and Statuses using OID:
dot1qTpFdbTable = 1.3.6.1.2.1.17.7.1.2.2
dot1qTpFdbPort = 1.3.6.1.2.1.17.7.1.2.2.1.2
MAC Addresses are received from:
dot1qTpFdbAddress = 1.3.6.1.2.1.17.7.1.2.2.1.1
dot1qTpFdbStatus = 1.3.6.1.2.1.17.7.1.2.2.1.3
Both pollers have also variants for devices which do not support community string indexing, those just have "NoVlans" suffixes in poller names.
Hi Zizi,
Did you actually manage to get the mac address table from Cisco switches using the Oids above?
I am getting "The oid is not supported"
