Hello
First Time User will have to install it and be the administrator . Any suggestions
Yes, admin guide is obviously your first pit stop. However, I would recommend you to go through entire installation on Sandbox first. This way you will see and feel yourself the entire process and steps involved. Take notes and repeat this in your production environment. This is how I would do it for the first time
Read the admin guide thoroughly it is your best location for all information you will need to install and setup SolarWinds.
