Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
False Positives ???
cayzac
Is there anyway to not send an alert on the first "failure"? In other words, I'd like the ping to a node to fail twice in a row before an alert is sent. I've seen false positives in the past and if it failed twice before alerting, that would eliminate most of that.
Find more posts tagged with
Accepted answers
All comments
EuropAssistance
I am looking for a similar thing. I would like to be alerted when say a server CPU hits 100%, but only if it stays there for a minute or two, not just blips...
Network_Guru
If you set your statistics and ICMP polling interval higher, you should be OK.
I get the CPU stats every 5 minutes and interface stats every 15 minutes.
Your CPU must be pinned for the full 5 minutes to see it at 100%.
As for ICMP if there is not response to a ping (actually 2 pings every 300 seconds),
then it goes into "fast polling" for 4 minutes (Pings every 30 seconds) before sending out an alert.
All these intervals are customizable, but I have found these settings to give the fewest false alarms.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
