Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Solarwinds NPM Installation Error!!
Chris474
I'm trying to install solarwinds NPM on my server. I have used the offline installer and the application installs correctly. My issue appears when I try to use the configuration wizard...
I input all the correct information for the SQL database that it will be connecting to and the correct user account details however when I press next the following error appears:
"Solarwinds cannot connect to SQL server. The original error is: the instance of SQL server you attempted to connect to requires encryption but this machine does not support it."
I have tried absolutely everything I can think of and am completely stumped. If you have any other ideas or have seen this error before, please let me know!!
Find more posts tagged with
Accepted answers
All comments
rocco_2016
Have you enabled TLS on the SQL server?
mesverrum
https://documentation.solarwinds.com/en/Success_Center/orionplatform/Content/Core-encrypt-database-connections-with-SSL.htm
Is it possible that your windows server does not have the same tls settings enabled as the SQL server?
Chris474
I have checked and they are both the same with TLS enabled in the registry
sum_giais
I guess covering the basics first - are you checking the 'Encrypt connections with SSL' radio button? I know... had to ask though lol.
Beyond that, is it at all possible that any TLS settings were changed and the server was never rebooted? (TLS changes require reboot to take affect.)
Are you using a Windows AD login to SQL, or a local SQL account for authentication during the configuration wizard?
What version of Windows is the SQL server running?
What version of SQL server is it running? Is it a shared SQL server? E.g. is there a way to validate it's not the SQL server?...
What version of Windows is the SolarWinds server running?
What version(s) is the SolarWinds products are you installing and configuring? The latest?
The configuration wizard should be adding the SSL certificate automatically as trusted. Might be worth checking via mmc / certs to validate if it shows as trusted I'd assume under computer account... (not sure if it would have even made it that far at that point with the failure you've seen though.)
Hope some of these 20 questions may help...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
