Hi,I would like to compare the NTFS permissions on certain shares and folders for two or more users / groups.
Can I somehow generate such a report with ARM?
Regards,
Ferdi
Hi Ferdi,
there's no real comparison.You could to a "Where has the user/group access?" for both users and compare it manually.
CheersBjörn
Hi Ferdi,it's possible, well sort of. There is no report. But you could use the scenarios which are available on the resources tab. In the resources tab type the user/group name in the search field and ARM will show underneath the resources the permissions which a user/group has. It's not limited how many scenarios you create. you can even adjust which permissions to show. Have you ever recognized this little gearwheel labled scenario in the resources pane?
