This expands on the excellent "CUSTOM SWQL TO MANAGE ASSIGNED APPLICATION MONITORS WITH SEARCH BAR" by hcy01uk . My view is a Component Credentials search that shows credentials for all apps and components:
Configuration is similar to the Original:
- Add a custom query resource and a custom HTML resource to the view.
- Edit the custom query resource.
- Paste the contents of Component_Credentials_Custom_Query.txt into the "Custom SWQL Query" box.
- Check the "Enable Search" box.
- Paste the contents of Component_Credentials_Custom_Search.txt into the "Search SWQL Query" box.
- Click the "Submit" button.
- Edit the custom HTML resource.
- Paste the contents of Component_Credentials_Legend.txt into the HTML code box.
