Getting thed attached error when attempting to back databases in the Database Manager. I have admin rights to the pc. Do I need to get admin rights to the SQL database somehow?
Are you trying to use NPM's Database Manager app to do the database backup? If so (and there's no other option available like MS SQL Server Mgmt Studio), you'll need to give the NPM SQL acct privileges to the NCM database. For privileges make sure the acct has the "db_backupoperator" role.
Also, which version of NPM are you using? The newer versions of the database manager automatically use the Orion NPM SQL acct. My suggestion should work for version 10.4+(possibly earlier can't remember for sure when the database manager app was changed to be like that), but it looks like you might be using an older version.
Kris Maxwell
http://www.loop1systems.com
