Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
03/10
03/04
03/02
02/16
02/11
01/11
12/23
12/17
12/14
12/10
12/09
12/08
12/03
12/01
11/25
11/23
11/13
11/12
11/10
11/09
11/03
11/01
10/27
10/22
Opera 72.0.3815.148
10/20
10/16
10/15
10/14
10/13
10/07
10/02
10/01
09/30
09/29
09/25
09/24
09/16
09/11
09/10
09/09
09/08
09/02
08/31
08/26
08/21
08/13
08/12
08/10
08/07
08/06
08/05
07/31
07/28
07/22
07/17
OpenJDK 8u262
07/16
07/15
07/14
07/09
07/08
07/07
07/03
07/02
07/01
Will this page be updated any longer? I have been seeing updates within PM when I logon, but I used to be able to get an email that reflected the updates shown on this page and I knew something was available.
Still waiting for that Google Earth update. And 7-Zip 16.04 was just released.
You should be seeing the update for 7-Zip 16.04 in the next day or so. As for Google Earth, the vendor has changed the installer and It is not possible to silent install with switches, which not work from Google Earth 7.1.4 +. It is, however, possible to create the package without direct download, but with install instructions. We're looking into this....
I've taken over the responsibility of updating the page and was doing it on a weekly basis, but I will make sure to update as they come!
I see updates for Adobe Acrobat DC Classic (15.006.30243) but where is the same update for Adobe Reader DC Classic? Also, need the latest update for Adobe Acrobat DC Continuous track. And to also add that Adobe has released a new version of Flash Player (23.0.0.185) that has also not shown up in PM.
I would appreciate any updates to these new versions. Thank you.
Trying to download and publish the new Google Chrome MSI. I am getting this error. Any ideas?
You can get Chrome from the link that a user provided in this thread below. I hope that solarwinds will put out a revised update with the correct download today though. This is a pretty basic thing for solarwinds to screw up on but historically its fixed quickly.
Google Chrome 54.0.2840.59 Business Enterprise MSI (Upgrade) with incorrect download location in catalog
The revised update has been uploaded now!
This has now been fixed and published!
Thank you for fixing the issue with the Google Chrome MSI. I mentioned some Adobe issues as well. Any idea when Adobe DC Reader and Adobe Acrobat DC (Continuous track) updates will be released?
Is it not this one from 10/1 you are looking for?
I have the Acrobat DC Update for Classic already (15.006.30243) but I am missing the update for Acrobat DC Continuous track. Current version is 15.017.20053.
Also, the Acrobat Reader DC (15.006.30243) Is still not showing up in my console within PM. I will try to manually force the download.
Hello. Is anyone having issues with Adobe Flash Player Distribution? You used to be able to download the latest versions from one page, but now you have to apply for a distribution license. I did this, but have not heard back from Adobe yet.
Megan, i'm new here, but I did have to apply for a distribution license. Especially since we are using an older version of Adobe Reader (XI). They will eventually get back to you within a day or two.
I have been hearing from a patch management mailing list that people are waiting weeks due to the huge volume of requests. They do get back to you, it just takes time.
Thank you for your reply.
Thank you for letting me know. At least I know it's not just me.
Any idea when the new version of Apple iTunes will be published? Should be version 12.5.3.
Anyone seeing this issue for downloading flash player catalog?
Adobe Flash Player Catalog with error Unable to download catalog. The file with URI: https://fpdownload.adobe.com/get/flashplayer/current/licensing/win/ could not be downloaded. Reason: Unable to find the directory for the download.
Any idea when and if the new version of the VLC Media Player will be published? New version is 2.2.4.
2.2.4 has been out since June
I don't seem to have it in the catalog.....
Just to check our configs are the same, I have VLC checked under the Solarwinds Update (Nofitications Only) Catalog
I have nothing checked under the Solarwinds Update Catalog
Thanx man. I went back and double checked my settings for third party updates. I 'assumed' since I saw VLC 2.1.6 that I should have the new stuff as well. I added VLC and now have version 2.2.4 available. That is what happens when you assume things, but I appreciate your help. : )
Are there any packages available to deploy the Chrome browser flash player plugin, a.k.a PPAPI? I don't seem to see the option to download it into PM.
We need this too, consistently having Flash update issues with Chrome since v54 was released. I know SEP causes some of the issues but have seen non-SEP related problems with it also. Guess I'll have to build my own PPAPI packages for now.
Any idea on when we can expect the MSI version(s) of Flash Player 24.0.0.194?
Thanks!
Yes, what gfraetis just said. Really need the MSI version of the Flash Player 24.0.0.194.
Garrett and hdwrguy, Adobe had changed their links which ultimately required us to talk to Adobe and verify our distribution license with them. This has all been resolved and the package has been published now.
Thank you, I see it has been published. However, when I try to download it, it doesn't seem to download or prompt me for the existing MSI. It stays stuck at 93 kb.....The same thing happens for the plugin.
I did verify by trying to download other Adobe products and they work fine.
