Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
03/10
03/04
03/02
02/16
02/11
01/11
12/23
12/17
12/14
12/10
12/09
12/08
12/03
12/01
11/25
11/23
11/13
11/12
11/10
11/09
11/03
11/01
10/27
10/22
Opera 72.0.3815.148
10/20
10/16
10/15
10/14
10/13
10/07
10/02
10/01
09/30
09/29
09/25
09/24
09/16
09/11
09/10
09/09
09/08
09/02
08/31
08/26
08/21
08/13
08/12
08/10
08/07
08/06
08/05
07/31
07/28
07/22
07/17
OpenJDK 8u262
07/16
07/15
07/14
07/09
07/08
07/07
07/03
07/02
07/01
I know this is quite delayed considering when the initial response was generated, but I was directed here by SolarWinds support. I've also been experiencing delays in receiving JRE patches as well. Currently, JRE7u40 is available from the Java site, but Patch Manager still has JRE7u25 listed as the last available patch. All other 3rd-party updates appear to be coming in just fine.
JRE7u40 was just released by Oracle this morning.
The previous update was JRE7u25 released on June 19.
You're not missing any Java updates!
Okay, my apologies. Today was the first time in a while that I checked the Java site to see if there was an update and u40 was available, so it had me a little concerned.
JRE7u40 was published to the catalog shortly before 9am CT this morning.
I have three duplicate packages in my Apple package list. The original three packages are listed as Expired, but their replacements are identical in wording, MSI product code and references. Why wouldn't this be a revision? There could be a difference that I'm missing. I just want to make sure folks with the IOS 7 itch won't come breaking down my door.
Well, it would help if I mentioned them, eh? Sorry, it has been a looong day.
Apple Mobile Device Support 7.0.0.117 (x64) (upgrade)
Apple Mobile Device Support 7.0.0.117 (x86) (full install)
Apple Mobile Device Support 7.0.0.117 (x64) (full install)
I'm checking on this, Jay. I'm not seeing the differences either.
Is there a link where we could download the updated cab files? Like Java and Firefox. The reason I ask is our Patch Manager is running on a closed network.
While it is possible to download the catalog and manually import it into a disconnected server, even if you did download/import the catalog, it would still be necessary to obtain the installation files for each update independently. However, there is no supported methodology for manually importing the update binaries, and while it is possible, doing so is a particularly tedious effort.
The preferred mythology is to use a similar sort of export/import process as you're using for the WSUS server. This process is described in a Geek Speak article from earlier this year: Using Patch Manager in a Disconnected Network Environment
Is there any status page that self-refreshes with the status of patches? I couldn't find one in the PM console window.
Patch Manager provides email notifications for synchronization results.
There is no web-based resource that is automatically updated.
This page is manually updated (by me), typically around 9am in the morning (schedule permitting).
There were Skype and Thunderbird releases in the past 36 hours, which will be posted in the next 24 hours.
I'll check it out. I have been doing the download of the catalog and the installation files for Adobe and it been working great. Firefox on the other hand I can never seem to get it to work right. Every month it is a different issue.
There is only one problem with this setup. Our disconnected network is a classified system. So if we create the SAS on the same network as the PAS we cannot move the SAS onto a internet connected network.
Can we integrate the patch management with microsoft wsus and system center configuration manager?
Absolutely. See the Patch Manager Evaluation Guide for ConfigMgr 2012 for more details.
I see Flash 17 in the table but i am not seeing it in in my console under software publishing. The highest I see is Flash 16.
Are you still seeing the issue ?
Flash 17 was added to the catalog on 13th March 12:45 GMT, When was last Sync operation performed to update the catalog ? if not please perform a catalog sync to bring down the updates.
Any word on when Chrome 43.0.2357.134 & Java 8u51 packages will be released?
They were released today!
Any chance we could get Webex software added to the set of patches available to be pushed?
I've added it to the "wish list". How about we also put it up for voting!
Vote here:
When will the new version of Google Chrome (47.0.2526.73) be released for Patch Manager?
Patch Manager has Adobe update packages for Flash Player, Shockwave, etc. However, I do not see any SolarWinds packaged Adobe Reader updates available. There are two areas under 'Software Publishing' for these. Adobe Packages (Packaged by SolarWinds) and Adobe Systems, Inc Packages (Stuff straight from Adobe). Will there be any SolarWinds packaged Adobe Reader updates available?
It is unlikely that SolarWinds will respond with a definite release date/time as it must be created and tested, but historically this happens fairly quickly; here are the last few:
46.0.2490.86 Released by vendor: 11/10/2015 Added to Patch Manager Catalog: 11/11/2015
46.0.2490.80 Released by vendor: 10/22/2015 Added to Patch Manager Catalog: 10/23/2015
46.0.2490.71 Released by vendor: 10/13/2015 Added to Patch Manager Catalog: 10/14/2015
45.0.2454.101 Released by vendor: 09/24/2015 Added to Patch Manager Catalog: 09/28/2015
45.0.2454.99 Released by vendor: 09/21/2015 Added to Patch Manager Catalog: 09/23/2015
SolarWinds will sometimes release Full installation packages for Adobe Reader but typically that is not for every minor version. You are correct that it has been a while since the last Full install version was added to the catalog - that was 11.0.10.32 on 12/9/2014.
You won't find any Reader update packages in the Adobe Packages folder since Adobe makes packages for the upgrades and SolarWinds does not want to duplicate what Adobe is already providing since that would be (even more) confusing.
Thanx for the feedback. BTW, I tested a few scenarios and what I found was the Adobe Reader 11.0.13 update was corrupted. I deleted it and re-downloaded it. I published it and it applied successfully. Sometimes the simple solution is the right one to try.
Well, 6 days since 47.0.2526.73 was released by Google and still no package from SolarWinds.
Chrome 47.0.2526.73 was added to catalog shortly. This delay is due to some unavoidable circumstances.
What a headache to keep up with all this, track it, troubleshoot it . . .
Thanks SW. Your work is recognized and much appreciated!
I downloaded the content for Firefox 43 Upgrade, but when I try to publish it, I get this. Tried deleting the content and downloaded it again. Same issue when trying to publish.
Ok, disregard this post. I was going to delete it, but then thought that explaining it may help others. The Credential ring was using a password that had been changed, so things started to fail. I updated the password and all is well.
Have a great day!!!
The new Chrome 50 packages need to be updated. The applicability rule says "WindowsVersion greater than or equal to MajorVersion=5 MinorVersion=1 Service Pack Major = 2 Service Pack Minor=0 Product Type=Workstation", but Chrome 50 dropped support for Windows XP and Vista. As a test I installed it anyway on my XP test VM and it gives you this every time you run it.
