Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
03/10
03/04
03/02
02/16
02/11
01/11
12/23
12/17
12/14
12/10
12/09
12/08
12/03
12/01
11/25
11/23
11/13
11/12
11/10
11/09
11/03
11/01
10/27
10/22
Opera 72.0.3815.148
10/20
10/16
10/15
10/14
10/13
10/07
10/02
10/01
09/30
09/29
09/25
09/24
09/16
09/11
09/10
09/09
09/08
09/02
08/31
08/26
08/21
08/13
08/12
08/10
08/07
08/06
08/05
07/31
07/28
07/22
07/17
OpenJDK 8u262
07/16
07/15
07/14
07/09
07/08
07/07
07/03
07/02
07/01
The last Flash update for 32.0.0.156 has a typo in the filename.. should be 156 instead of 142.. prob because it was copied from the 142 version update rules..
Just sending to be aware.. thanks!
When will Adobe Flash player 32.0.0.171 be released to the solarwinds catalog?
Thank you!
On a related note, do you know why we aren’t getting future updates for Adobe Acrobat 17.x (which is the 2017 Classic Track)? According to Adobe’s website (www.adobe.com/.../index.html) there are at least two newer updates.
Here’s the full list from that webpage. Notice that 17.011.3018 and 17.011.30140 came out in April 2019, but I don’t see them in Patch Manager. I do see 17.011.30127 from Feb 2019.
I see Mozilla Firefox 66.0.5 listed, but I'm not getting it when I synch. Was it pulled or?
When will Adobe Reader DC 2017 Classic 2017.011.30142 and Adobe Acrobat DC Continuous 2019.012.20034 be released to PM?
I need Adobe Acrobat 2017 version 17.011.30142 (classic Track). Is this available?
They're in the Adobe Packages Folder and not the normal Adobe Systems, Inc. Packages folder. Someone over at Adobe must have made a mistake.
When will Adobe Flash player 32.0.0.192 be released to the solarwinds catalog?
Thank you!!!!!
Please publish Adobe Flash Player 32.0.0.192. Thank you.
I'm still not pulling down FireFox 66.0.5, which shows was published 7 days ago. Hello Solarwinds? Anyone?
The packages for Google Chrome 74.0.3729.169 have the incorrect download URL. Instead of pointing to Google, the are pointing to the desktop:
file:///C:/Users/admin/Desktop/Google Chrome Business Enterprise MSI/Google_Chrome_Business_Enterprise_MSI_74.0.3729.169/x86/googlechromestandaloneenterprise.msi
I'm sure you already know this, but I just ended up downloading the software and modifying the package to point to my downloaded software.
That is what I ended up doing. I just wanted to point the issue out to SolarWinds PM team.
UltraVNC 1.2.2.4 was released over a month ago on March, 14th and is still missing from the catalog.
Is there a similar table of HP Business Clients Packages? Specifically, I'm looking for the status of HP Notebook System BIOS updates.
jeffashizawa wrote:
Not really; SolarWinds doesn't provide that view as the HP catalogs are made/updated by HP and not SolarWinds.
This is the list of the third-party catalogs to which Patch Manager can connect & pull updates from (out-of-the-box):
Catalog Name
Publisher
URL
Adobe Systems Acrobat 10 Catalog
Adobe Systems, Inc.
http://armmf.adobe.com/arm-manifests/win/SCUP/Acrobat10_Catalog.cab
Adobe Systems Acrobat 11 Catalog
http://armmf.adobe.com/arm-manifests/win/SCUP/Acrobat11_Catalog.cab
Adobe Systems Reader 10 Catalog
http://armmf.adobe.com/arm-manifests/win/SCUP/Reader10_Catalog.cab
Adobe Systems Reader 11 Catalog
http://armmf.adobe.com/arm-manifests/win/SCUP/Reader11_Catalog.cab
Dell Business Client Update Catalog
Dell
ftp://ftp.dell.com/catalog/DellSDPCatalogPC.cab
Dell Server Updates Catalog
ftp://ftp.dell.com/catalog/DellSDPCatalog.cab
Hewlett-Packard Client Updates Catalog
Hewlett-Packard
ftp://ftp.hp.com/pub/softlib/software/sms_catalog/HpCatalogForSms.latest.cab
Hewlett-Packard Server Updates Catalog
ftp://ftp.hp.com/pub/softlib/software10/COL25555/sy-65640-1/ProLiant.cab
If you pull down the HP Client catalog .CAB, you can open it and find an .XML that lists them out, but it'd likely be easier to view the catalog contents from within Patch Manager as you could easily sort by date or put a filter on the column to look for certain text strings.
Perfect. Thank you sir.
Guys, when will Chrome version 75.0.3770.80 be released into PM?
When will Adobe Flash Player 32.0.0.207 be released to PM?
Thank you
"The file that was selected does not match the name in the package." when importing source for a package.
Hi folks. When trying to Import Source for Flash Player 32.0.0.207 PPAPI EXE (Upgrade) and Flash Player 32.0.0.207 PPAPI MSI (Upgrade), an "Invalid" dialog box appears with the text: The file that was selected does not match the name in the package. Select another file that matches install_flash_player_32_ppapi.msi
The problem is that the filename configured for both packages has a space character before the ".exe". You are able to import the source files for both EXE and MSI versions if you add a space character before the ".exe" in the file names of the EXE and MSI distributables that you got from Adobe.
I hope this solution helps others.
Foxit Enterprise Reader 9.6.0.25114 ( Full installer not upgrade ) Looking to see why these packages are using .exe for the Enterprise version of Foxit as when the Enterprise version is downloaded via the Foxit website it is in MSI format. This leaves the Package useless as it will not install if a previous Enterprise Version is installed which is also in a format of .MSI.
Can there be an added package to support the MSI format or instructions to modify the existing to use the MSI package.
When will Google Chrome 77.0.3865.90 be available? It patches a critical vulnerability. Thank you.
Thank you so much for keeping it all viable!
Google has released Chrome version 78.0.3904.87 for Windows, Mac, and Linux. Google Releases Security Updates for Chrome | CISA
Chrome 78.0.3904.87 was available in Patch Manager when I had it check for updates!
Long time reader, first time poster.
Any idea when the next update will be posted? FileZilla is at version 3.46.3. There may be other programs with new updates as well.
Also, is my brain foggy? I could have sworn Adobe Acrobat and Reader DC were listed in the past but are conspicuously absent now.
Happy holidays.
FileZilla 3.46.3 has just been uploaded to the catalog, apologies for the delay in getting that particular update processed. The Adobe updates are maintained directly by Adobe. In order to gain access to their catalogs you can add custom catalogs to Patch Manager, by going to Synchronization Settings->Other Catalogs and use the links here.
any indication of when Java 8u241 will be available?Thanks
