Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
03/10
03/04
03/02
02/16
02/11
01/11
12/23
12/17
12/14
12/10
12/09
12/08
12/03
12/01
11/25
11/23
11/13
11/12
11/10
11/09
11/03
11/01
10/27
10/22
Opera 72.0.3815.148
10/20
10/16
10/15
10/14
10/13
10/07
10/02
10/01
09/30
09/29
09/25
09/24
09/16
09/11
09/10
09/09
09/08
09/02
08/31
08/26
08/21
08/13
08/12
08/10
08/07
08/06
08/05
07/31
07/28
07/22
07/17
OpenJDK 8u262
07/16
07/15
07/14
07/09
07/08
07/07
07/03
07/02
07/01
UPDATE: I followed the procedure from this URL and was able to add this catalog and I now have Adobe DC Reader Classic Track 2017 updates showing within PM.
Manually add the Adobe DC Catalogs to the synchronization settings - SolarWinds Worldwide, LLC. Help and Support
http://armmf.adobe.com/arm-manifests/win/SCUP/ReaderCatalog-2017.cab
Thank you for this info. I need something that patches Adobe Acrobat Pro 2017. Here is the About page from our version
Is there a catalog for this product? I don’t see patches that say “adobe acrobat pro 2017”.
Thanks!
Jim
Add this catalog by using the procedure above and you will have the Adobe Acrobat DC Classic 2017 catalog.
Please add Mozilla Firefox 60.1.0 ESR 64-bit for both install or upgrade.
You only have 32-bit and the previous version 60.0.2. We would like to deploy the 64-bit version and try to come up with a way to wipe all previous Firefox in our environment.
Currently we have a wild mix of 64bit, 32bit, quantum, 52.x.x esr, etc... We want to standardize on JUST the 64 bit of Firefox Quantum ESR.
Thank you!
Not seeing Google Chrome 67.0.3396.99 available after a synchronization.
Have you tried syncing again today? If so, can you confirm if you are still not seeing the package?
HelloWhen will Java 181 be available? as it isnt in the list above
As stated above, is there a time frame for Java 8.181?
Thanx
its been updated and now says
8u181
07/19/18
however, upon a synchronization there is nothing there, no reference to update 8u181 in Patch Manager, checked everywhere.
didnt get a reply from anyone!?but it is available nowthank you
Java 8.181 was finally showing up inside PM, however it is not working. Using the default upgrade package it just keeps saying not applicable.
Apologies for the delay. Glad to see you are seeing the update now. Can you confirm that it is working ok for you?
Can we also get Java 8u182 and the latest versions of Java 10? Whenever you add a new version of Java can you make sure we go both the xx1 version (security updates) and the xx2 version (new features)?
It seems that 8u182 has not been released by the vendor yet - Java 7 and Java 8 Releases by Date
Not seeing Google Chrome 68.0.3440.75 after Synchronizing. Most recent I have is Google Chrome 67.0.3396.99. Anyone else seeing this?
When will Google Chrome 68.0.3440.84 be released into PM for deployment?
Thanx!
Guys! Google is now on 68.0.3440.106! I have had to resort to using SCCM to deploy this because PM is not updating the packages...
The latest version of Chrome is now available in the catalog.
Synchronizing gives me the latest Chrome package, but I'm not seeing Firefox 61.0.2. This is getting to be a nuisance.
Not seeing the Adobe Air 30.x updates.
Am I missing something?
Ok, don't know what happened, but it showed up yesterday.
Will the newer versions of Java (ie v9 and v10) be made available via Patch Manager? With Java's announcement that from Jan 2019 updates for v8 will require a corporate licence, i guess we are going to look at updating to the latest version.
You can view relevant information in this thread: End of Java in Solarwinds Patch Manager?
Google Chrome 69.0.3497.81 ??
does anyone see the flash patches for Adobe Flash 31.0.0.108 (09/11)? The last patch I see is for 30.0.0.154.
Does anyone have patches for Adobe Acrobat 2017 in patch manager? Specifically Adobe ACrobat 2017 version 17.011.30099. I see Adobe Reader 2017 version 17.011.30099, but not Acrobat.
Synchronized 1 hour ago and no Adobe Flash 31.0.0.108 yet :-(
I do have the patch you are looking for, but had to manually add the catolog to get it.
If you follow this guide: Manually add the Adobe DC Catalogs to the synchronization settings - SolarWinds Worldwide, LLC. Help and Support
The catolog path I used is: https://armmf.adobe.com/arm-manifests/win/SCUP/AcrobatCatalog-2017.cab
The different paths can be found: SCCM-SCUP — Enterprise Administration Guide You want the Classic track 2017.
I hope this helps.
Thank you for Chrome! For some reason, I’m not the new Chrome nor am seeing Flash 31.x.
I've received the Adobe Flash update last night.However, and I know this isn't an Solarwinds issue, when I try and download the MSI from Adobe's distribution link it just loops and refreshes the page rather than downloading. Is anyone else experiencing this?
It appears that the detection logic for the Adobe Flash 31.0.0.108 patches is not correct. It does not think the patch is needed on any of our machines. We are currently running version 30.0.0.154.
agsw,
I have the same problem as you. We run 64-bit Windows 7.
I see the problem. In the 31.0.0.108 package, under Applicability Rules, the author forgot to update the lines that look for an existing Flash32_30_0_0_154.ocs file, to look for the new Flash32_31_0_0_108.ocs file.
Actually, it should be looking for Flash32 under SysWOW64, and Flash64 under System32, as this all falls under Processor Architecture=x64 in the Applicability Rules. That seems to be a long running bug looking back at previous versions of the Flash Player package.
Looking a bit further, the Installed Rules are also incorrect, and refer to the old .ocx file.
Someone rushed this out and didn't take the time to test that it worked.
Sorry to hear you are having issues with the latest Flash update. We are currently reviewing the Applicability and Installed Rules and will update accordingly.
We have just uploaded a revised Flash 31.0.0.108 package which resolves the issues you discovered. If you synchronize with the catalog, the old update will be replaced with the revised one. Apologies for any inconvenience caused and thanks for flagging the issues.
According to Adobe that latest version is 31.0.0.108. This package has been available within Patch Manager since 09/11.
I synchronized successfully the solarwinds catalog yesterday and today multiple times - but no Adobe Flash Player 31.0.0.122 which should be released on 9th october and yesterday in catalog.
I am having the same issue. Adobe Flash Player 31.0.0.122 is not showing up after synchronizing.
i'm still not seeing Adobe Flash Player 31.0.0.122 after synchronizing.
i'm not seeing Adobe Flash Player 31.0.0.122 either; even after waiting a few days and running manual synchronizations
I finally got them this morning...
Apologies for the delay with access to the latest Flash packages. We discovered an issue on our 3rd Party Update servers that was preventing synchronisation with the Flash packages. If anyone continues to have issues with Flash syncronisation, can you please let me know? Apologies for any inconvenience the delay may have caused!
Any idea when you guys will release the Java 8.191 packages?
Yes
Does anybody knows when chrome 70 will be available in SolarWinds PatchManager? Thank you
Hiwhen will Chrome 70.0.3538.67 be available?Thanks
Looks like Java 8.191 was released, however the package boot helper does not include Java 8.181 uninstalls. It only goes up to Java 8.172.
Thanks for flagging this. We have just published revised packages which include uninstallation for 8u181.
If we have Firefox 60 ESR 64-bit pushed out, how do we maintain it with SolarWinds Patch Manager? Your ESR does not offer a 64 bit version. ESR is geared towards businesses, as patch manager is geared towards businesses (you wouldn't invest in patch manager for you home would you?).
So this doesn't make sense why I'm not seeing Mozilla Firefox 60.3.0 ESR (x64) (Upgrade) in the list of patches for Mozilla Packages.
Hello,
We are waiting for the latest security updates for Flash 31.0.0.148. They were release on 11/13. Do you know when they will be available?
Thank you,
Anna
Hi together,
is there a way to update Teamviever with SolarWinds PatchManager? Are there packages which can be improted? Or only by creating it manually?
thank you for your support
The latest Flash updates are now available in the catalogue.
When will DameWare DMRC 12.1.0 be released in Patch Manager? It is already available in the SW customer portal.
When will be available Chrome Release 70.0.3538.110?
Lately, the time between a third party published a new version product, and Solarwinds catalog publish it, it's very high.
This is a problem with versions that correct security problems.
When will be available Chrome Relase 71.0.3578.80?
Chrome Releases: Stable Channel Update for Desktop
>https://chromereleases.googleblog.com/2018/12/stable-channel-update-for-desktop.html<
This update includes 43 security fixes, some of them with high CVE score.
Regards!
The email from Thwack shows Google Chrome 71.0.3578.80 being available but it has not yet shown up in the PM console. I have manually synchronized without success.
I am still not seeing Flash 32.0.0.101 , any updates?
You may need to synchronize as it is showing in my PM console. Actually deploying it tonight.
When will Apple iTunes 12.9.2.6 be available in PM?
Please add Mozilla Firefox ESR 60.4 Thank you!
Dave
Firefox ESR 60.4 was published on Dec 17th. Please let me know if you are unable to see it within your Patch Manager.
When will the new Flash updates be posted? Version 32.0.0.114 was released.
Any idea when the new version of Adobe Flash player (32.0.0.114) be released to PM?
Thank you
When will Adobe Flash player 32.0.0.114 be released to the solarwinds catalog?
It was released by Adobe seven to eight days ago.
When will be available Sun Java 8 Update 201?
Curious when Solarwinds WMI providers 2.1.6.6226 will be available.
Java Runtime Environment 8u202 (x86 for x64) (Upgrade) on Windows 10 Enterprise - keeps re-installing every time I check for updates.
Windows 7 does not seem to be affected.
When will be available Google Chrome 72?
These providers are now available in the catalog.
Apologies for the inconvenience caused. We have uploaded revised Java packages to resolve the issue.
When will Google Chrome version 72.0.3626.81 be released into PM for deployment?
and just like the last set of providers, its broken. You have to manually edit the package and press the download button to fetch the .exe
I must say. Quality control seems to be an afterthought these days...
Very sorry. Direct download link setting has been adjusted in revised packages and now updated in the catalog.
Guys, any update on the latest Google Chrome release??
When will be latest Chrome available?
More than one week after been released isn't available.
I ended up having to deploy the new version of Chrome with SCCM. I could not wait any longer. Disappointing.
its very disappointing, and becoming regular.
When will Adobe Flash Player 32.0.0.142 be released to PM?
this still isnt working for us, still goes and installs everyday. have had to 'not approve' the update
we are still waiting for the latest chrome & flash.an explanation of why releases are very slow would be good also please.
I'm also looking for the Adobe Flash Player 32.0.0.142 updates.
When will 7-Zip 19.00 be released to PM?
Hi Solarwinds Team,
we urgently needs winrar 5.7 because there are already attacks against the valnurability in older WinRar Versions. Do you know when it will be available in the patchmanager?
Critical WinRAR Flaw Found Actively Being Exploited | Threatpost | The first stop for security news
Google released a new update for Chrome yesterday March 13 due to security vulnerabilities. I got a CERT notification and updated my home computers.. is this going into your catalog soon so we can patch our enterprise?
Google Chrome v. 73.0.3683.75 has been released. Please don't take as long as before to release this. We use Chrome for almost everything and our financial institution cannot run an outdated Chrome browser.
When will Adobe Flash player 32.0.0.156 be released to the solarwinds catalog?
Do you not care about your customers? Ivanti had google's v73 update out about 6pm or earlier yesterday March 13th..
How long does it take to create the rules for 1 application update?
Latest Flash update is now in the catalog.
Latest Chrome update has just been added to our catalog. Hopefully the timeframe for this version is acceptable, apologies for the delay with the last version.
Lots of people eager to jump in here and complain about this update or that update not being in the catalog right away, but nobody cares to say "thank you" when the updates are actually added in? I realize this is a service that we pay for, but what ever happened to common courtesy, is the entire world that entitled that being polite is no longer necessary?
Pathetic.
Thank you, @jhynds, for getting Chrome and Flash added in!
Thanks again for the updates! Just an FYI, the download link for the FileZilla 3.41.1 update points to FileZilla 3.41.2. I was able to duplicate the update and edit it for the newer version, just wanted to bring it to your attention.
Again, thank you for keeping us updated!
The last Flash update for 32.0.0.156 has a typo in the filename.. should be 156 instead of 142.. prob because it was copied from the 142 version update rules..
Just sending to be aware.. thanks!
When will Adobe Flash player 32.0.0.171 be released to the solarwinds catalog?
On a related note, do you know why we aren’t getting future updates for Adobe Acrobat 17.x (which is the 2017 Classic Track)? According to Adobe’s website (www.adobe.com/.../index.html) there are at least two newer updates.
Here’s the full list from that webpage. Notice that 17.011.3018 and 17.011.30140 came out in April 2019, but I don’t see them in Patch Manager. I do see 17.011.30127 from Feb 2019.
I see Mozilla Firefox 66.0.5 listed, but I'm not getting it when I synch. Was it pulled or?
When will Adobe Reader DC 2017 Classic 2017.011.30142 and Adobe Acrobat DC Continuous 2019.012.20034 be released to PM?
I need Adobe Acrobat 2017 version 17.011.30142 (classic Track). Is this available?
They're in the Adobe Packages Folder and not the normal Adobe Systems, Inc. Packages folder. Someone over at Adobe must have made a mistake.
When will Adobe Flash player 32.0.0.192 be released to the solarwinds catalog?
Thank you!!!!!
Please publish Adobe Flash Player 32.0.0.192. Thank you.
