Hello,
I have some Brocade switches, 3000, 5100 and 5300 models. Only 5100 model is working, the rest models has timeout problems, despite the server where I have the machine can connect via putty to these devices.
This is the debug
<NEWSESSION CatTools 3.11.4 05/03/2019 10:04:47>
<PROTOCOL=SSH2>
<DEVICE TYPE=Brocade.Switch>
<ACTIVITY TYPE=Device.Backup.Running Config>
<ACTIVITY SCRIPT=C:\Program Files (x86)\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=Brocade_3000>
<C Err=The current connection has timed out. 10:05:08>
<D 10:05:08>
<SCRIPT VALUES>
<HOSTNAME="D1PRFCBCK02:FID128:admin">
<PROMPT VTY="D1PRFCBCK02:FID128:admin>">
<PROMPT ENABLE="">
<PROMPT CONFIG="">
<C Err=The current connection has timed out. 10:05:30>
<D 10:05:30>
<SCRIPT VALUES>
<PROMPT ENABLE="">
<PROMPT CONFIG="">
<C Err=The current connection has timed out. 10:05:51>
<D 10:05:51>
<SCRIPT VALUES>
<PROMPT ENABLE="">
<PROMPT CONFIG="">
Could you please check and advise?
