Hi all
If it possible to integrate with the NPM in any free database server(eg--My Sql)
You can use SQL Express, which is a free download from Microsoft. We don't support running the Orion database on MySQL.
You can find our system requirements for Orion here:
http://www.solarwinds.com/products/orion/info.aspx
Thanks Cdoyle,
But SQL express database size is very less correct.
If we install the NTA means it will full.
Pl sugges how can proceed this case.
Thanks & Regards,
B.patturaj
Hi B patturaj--
The only options for Orion are SQL--which is not free--and SQL Express and if you run SQL Express with NTA, we do not recommend it as a long-term solution as it will only support approximately two interfaces for a limited period of time. It's usually for evaluation purposes only.
Do you currently own both NPM and NTA? If so, we recommend MS SQL as your database. Please refer to the document Caroline attached.
M
