Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
TFTP Server on XP SP2 does not work
rogerswi
I can ping the tftp (V 5.3.23) server and file config> is set to transmit and receive but I can't receive or send a file. I get a timeout. There is no entry in the logfile.
The tftp is running (task manager).
I uninstalled and reinstalled it.
With the tftp on w2k I have no problem at all.
Thanks for any answer.
Roger
Find more posts tagged with
Accepted answers
All comments
DonYonce
Roger,
The XP SP2 firewall has blocked access to the TFTP Server.
You must add an entry to the Network Connection to allow access to port 69 (TFTP Server).
I do not have an XP machine in front of me at this time and cannot remember exactly where the firewall settings are. But, I think they are under the "Advanced" tab on the Properties dialog box for your Network Connection. Open Control Panel and select "Network Connections". Then double click on your network connection. I think it's under the "Advanced Tab"
rogerswi
Don,
Ufff, you are right.
Thanks a lot.
Anto
I had the same problem and added port 69 but still is not working. The tftp server is running but it is not listening on any port. What am I missing? can naybody help?
Thanks....
video_jock
I to am having the same problem. I have WINXP SP2 and I added Solar Winds to the exceptions list and even put it in manually under port 69 and I am still getting that dreaded %error timed out error. Any helpful information would be greatly appreciated.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
