Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
ICMPv50.ocx not correctly registered
shankarsahu
I'm new to this forum & I wanted to quickly fixout a problem which I'm currently facing with the Solarwinds Engineer 7.1 toolset installed here.
Here is the detail of the problem:
I've installed the toolset on a citrix server, as to share the application to my group of colleagues here to monitor their n/w's. Now from the server (where the appln. is installed) the Network Performance monitor (for instance been tried to access) works fine, but the same tool, when tried for any of citrix clients it gives the below mentioned error msg.
Component 'ICMPv50.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
Request you earliest support, to resolve this problem.
Thanks in advance.
Regards
Shankar
Find more posts tagged with
Accepted answers
All comments
BK
I would guess that when you installed the Solarwinds Package, you did not install in Administrative mode.
I have seen a simlar problem with Windows Terminal Service. If you did not enable Administrative Install Mode, Windows will redirect file saves intended for the c:\Windows\system32 directory to a system32 directory located under the users documents. The one user who installed the app works great, for everyone else the files are not found.
When installing on a Windows Terminal Service, you had to use the add/remove programs on the control pannel to add a new package. This would disable the file redirection until the setup package completed.
You could also use the CHANGE USER /INSTALL command at the command prompt before you started the setup.
Hope this helps.
BK
Nobody Special
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
