Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Solarwinds and SuSE Linux
baxel
Hi all,
I have trouble to monitor my SuSE Linux 9.2 System in Solarwinds Orion (Version 7.5).
I've installed the NET-SNMP Agent in the Version 5.0.9, 5.1.2 and 5.2.1.
I can start all different Versions of the agent and access the SNMP MIBs through Solarwinds, however Solarwinds always reports, that the Node is Down.
(I've compiled the Net-SNMP Package with ./configure, make, make test and make install)
Has anybody experienced the same Problem with SuSE 9.2 or has anybody a Solution for my Problem?
cheers from cold Switzerland
alex
Find more posts tagged with
Accepted answers
All comments
DonYonce
baxel,
Node Up/Down status has nothing to do with the SNMP agent. Node Up/Down status is determined via ICMP (PINGs). SNMP is used for interface status, traffic, CPU Load, disk space, etc.
Also, traffic, CPU load, etc will not be collected if the Node status is down.
I suggest you find out why the Linux box is not responding to PINGs first.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
