Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Polling engine problem
Cygnuz
hi,
I need to monitor resource at a remote site, so i installe a new polling engine, call this B, without web server and without db. The primary polling engine (with db and web server), call this A, can talk with B trought a VPN. When I logon on A and I open "Orion System Manager" I can see the 2 polling engine, both with green light, but when I try to connect to polling engine B (from the system manager in A) it tell me that the host doesn't exist. The same happen when I try to connect from b to A. Using a sniffer it seem that during this process A try to authenticate to B trought a RPC service and this fail. Do I have to create a special user Account or something else?
Find more posts tagged with
Accepted answers
All comments
BK
The answer would be yes. The RPC is trying to use your userid and password that you logged in with on A to authenticate on B that you are allowed to connect to the service.
Try creating an identical userid on B with the same password as the user account on A you are logged in with.
BK
Nobody Special
Cygnuz
Thanks for your answer,
I already have it, the accounts username are "Administator" and passwords are the same, maybe the problem is due to OS type? win 2000 on A and win xp on B.
How can I solve this?
Cygnuz
After some other investigation i guess the problem can be windows xp sp2, is it possible?
Cygnuz
Still I can't solve the problems, i've notice the following message in event registry with event id 10009:
"DCOM was unable to communicate with the computer B using any of the
configured protocols"
any help would be appreciate!
thank
Cygnuz
Can someone tell me at least which ports are used during this authentication process, so I can sniff just for this traffic?
thank
Cygnuz
still I can't solve the problem!
I don't understand why if I wan to use sistem manager from A to use polling engine on B I have to connect to B using DCOM RPM while the database is installed on A.
Anyway I think this mean that SW need some windows service active that are not mentioned on the tutorial!!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
