Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Loss of Polling Data between Certain Hours
kindbro
Ok, I have a question for the Orion Forum Trolls. Ive had a problem with my sites getting complete polling information from 1230am to 230am. If you were to look at any interface you would see breaks in the graph line between those times. Has anyone ever had this problem, or can you please point me in the right direction as to how I can fix it. Your help will be greatly appreciated.
bret
Find more posts tagged with
Accepted answers
All comments
jtimes
Sounds like your nightly db maintenance. Check the maintenance schedule. You might want to do that on a weekly basis, depending on you particular SQL implementation (MSDE or full blown SQL). Search the Forum for
maintenance
or
database
for addition tips.
Here is a good thread around what you described:
www4.solarwinds.net/.../topic.asp
kindbro
Thanks jtimes, I guess I need 2lrn2query. There is a lot of good info on the link. My DB is 6.5 gigs, and the last time we ran a compact was in 2005. Im hoping the compact will solve my problems. Others hinted around that I could have my backups running around the times that I have the breaks in my polling, my loss of pollings are between 1230 and 230, but the only thing happening at that time is my Opimization which starts at 100am and my DB backup which runs at 215am. I guess I should schedule these to be run on the weekends.
kindbro
So, I finally got thru to Solarwinds support and found out what was going on. Yes I did have scheduled jobs running between the hours where I had the lost polling data. What was interesting though is that the jobs kicked off at 1am, but my loss started at 1230. So what was going on? I guess before the 1am job kicked off, there is some preliminary stuff that happens before the 1am kickoff, so 1am actually was 1230am. I have since deleted that job and will see if it fixes my problem tomorrow, I will let you know then.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
