I want to assume this but just in case I will ask anyway. If a Node us unmanaged does it stay on the "Network Node Elements" count on the Poller tab in the admin menu... and by default those nodes interfaces also? Thanks!!!
Yes, it still shows in the element count for nodes and interfaces. However, I'd assume that since there is no polling, then the job weight isn't adversely impacted by having those still assigned to the poller.
That's what I thought, Thanks!!!
