Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Empty Config files
MicSchmidt
I have a daily scheduled job running witch downloads and saves all the changed configs. Sometimes one or more config files are empty and thereby different then the existing config. Does anyone have an idea of why I recieve these empty files? There are no problems if I manually download the config.
Find more posts tagged with
Accepted answers
All comments
bleearg13
I am having the same problem. I found another post in the forums here that said to try changing the number of simultaneous downloads down to 5 instead of the default of 10. I tried this and I'm still having the issue - even after bringing my simultaneous downloads to 3.
Grabowski
I am having the exact same problem.
It seems that there is a correlation between when these blank configs are downloaded and when the WAN out to the location of the node has had problems, which makes sense if the download is interrupted. What doesn't make sense is that Cirrus in the first place acknowledges blank configs as valid. I mean: There IS no such thing as a blank config! Cirrus should be smart enough to realize that.
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 3.0 DL-500 Apr. 2006 (8.3.53)
Orion Application Monitor 7.8.94
Orion Web Engine Version 7.8.133
Orion NPM SLX 7.8.5 March 2006
Alert Manager 8.1.15
bleearg13
I think I've actually narrowed my problem down to SSH. It seems that configs retrieved using telnet don't seem to do this. I changed some of my devices to telnet and the problem has gone away. Still a very big problem, as I can't continue to run telnet all the time.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
