Hi
I have set up a Universal Device Poller for HP printers which reports the current message on the printer display. The OID is 1.3.6.1.4.1.11.2.3.9.1.1.3.0, MIB is set to raw data, SNMP is set to GET, polling is type node and status is enabled.
When I assigned this poller I did a test against the HP printers and it returned the values as expected, as in the following screen grab:
However the data on my orion website isnt updated:
As you can see from the screen grab one shows the status (but over a day old) and the others show nothing.
I am using NPM v9.5.
Does anyone know why this could be?
Thanks.
