Just a quick one, time saver.
When you search for a node, and there is only 1 node returned, can you just go to that node instead of waiting for the returned list to show, then clicking on the single node?
(another side note/question. if the node search is successful, can the Nodes with Caption similar to "srvr" be a different color than bright red? Usually that color (Bright Red) signifies a problem with the search. The subtitle in the returned results page is the same big red font whether the search returned results or not)
Maybe I'm being too picky but just my .02
Zach
