Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
NetFlow setup on layer 3 devices
joesim
To "properly" monitor flows, Cisco says to monitor flows from all active interfaces on a given Layer 3 device. That would mean a router with two interfaces needs two interface licenses.
Can anyone confirm if this is true?
As an example, if I have a router with a fast ethernet interface connected to a core switch and a T1 serial link connected to a remote site, is it 'good enough' to just montior the serial link if your goal is to see all traffic to and from the remote site? Or do I need to burn another license to monitor the fast ethernet interface as well.
Find more posts tagged with
Accepted answers
All comments
Coreshock
To gather the Tx and Rx flows to your remote site you will need to burn a license for both you ethernet and serial interfaces. Netflow only works on the ingress direction of the interface(with exception of using "true" MPLS and egress ip flows). So in order to see full data stream you need to have it applied to both interfaces.
larry.rice
I would open a quick TAC case on this.
I was able to set up ingress and egress flow on my devices (at least with new code).
38xx w/ 12.4.xx
on my interface
ip flow ingress
ip flow egress
Josh_Stephens
Larry is right - on some code levels you can set it up on the ingress and egress. Depends on the IOS version...
Josh Stephens
SolarWinds R&D
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
