Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
A couple of thoughts for the Map Maker...
iunderwo
This application has come a long way since its inception, so here are a couple of more ideas for it.
Currently, line status can be based on one interface. It would be nice to configure the line to split status with a different interface on each endpoint controlling its respective half. This would be more convenient than using two lines, and would save space on the map.
Another feature idea would be to set a temperature scale of sorts for line status. For example, from black through bright green or another color combination based on line utilization. This could even be done with a three points...like green to yellow for 0-50%, and yellow to orange for 50-100%, and being able to set a link fail color.
The two features combined would make for some extremely pretty (and easy) maps.
// Ian Underwood - Service Management
// Level 3 Communications
Find more posts tagged with
Accepted answers
All comments
iunderwo
Another idea I had would be for accounts with limitations and maps.
Currently, it's setup so a user can view all nodes on the map, or have those nodes removed from the map.
I'd like to see a third option to not show status. For example, I have a map which shows the layout of my NPM network. The good nodes are green and the linsk are colored. However, if an account limitation doesn't allow a user to view the item, I would like it to reflect status as if no object were selected for the view.
For the all nodes view, the web engine should not generate hyperlinks to items users don't have access to. This would work just as well for me as the above, and should be easy to code in.
iunderwo
And yet another thought...
Allow specification of a background color which also asks for the size of the map. This is quite useful with background textures, and would be particularly useful with a blank specified color.
jacobsr7
Finnally, I think the ability to use Cisco Icons (.VSS or .PTT) would be a great improvement. Not to say that the icons aren't good but I think Cisco's are better.
Network_Guru
You can copy and paste the cisco icons directly from Visio into mapmaker.
Check the following reply in this post:
www2.solarwinds.net/.../topic.asp
The SolarWinds Map Maker update in Version 7.1 will allow copy and paste of device
icons directly from Visio (or other graphics programs).
Select the device icon in Visio and select "Copy".
Within Map Maker, select "Paste Special" from the Edit menu.
Also see this post if it's not working for you:
-=Cheers=-
NG
lavelanet
I would also like to make a request for those features listed in the first post. Especailly line utilization where the admin could set the thresholds.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
