Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion questions
iaminit
When you use Mapmaker to build a map and then add the objects to be monitored on it, where is it specified what info is displayed on the pop up when you hover your mouse over it in the web view? I would like to customize what I want to see, for instance, if I have a map of a switch, and add nodes to each switchport, I would like to pick what it displays when I hover over it with the mouse. Can this be done?
Also, is it possible to add "groups" to the window pane in performance montior? We have a long list of devices and it would be nice if we could group them under a defined group name.
Find more posts tagged with
Accepted answers
All comments
trm33
This is from Solarwinds on how to change the mouse roll over
This can be done, however all the macros have not been tested with it. Please log in to your website as Admin. Click the Admin button at the top. Then add the following to the URL in the address bar.
MapToolTipTemplates.asp
This will give you the ability to add Macros to the popup box.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
