Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Interface Alert Issue
gbrance
Had a weird alert issue with Orion NPM.
I have some alerts setup for some key interfaces on a Cisco 4500 catalyst. We had a alert get tripped when a interface when into Down Status. If you look at our Orin NPM web page you see a triggered alert that the interfaces are down. However the alert engine paged out the interfaces were up. I went into the switch and confirmed that the interface's in question were down. I have the alert set to trigger when the interface goes down. I have the alert to reset when the interface is up. Here is the Macro string for the trigger alert that gets both paged out and e-mailed out for the interface change
Subject Alert: ${FullName} on ${NodeName} is ${Status}
Message Alert: Interface ${FullName} on ${NodeName} is ${Status}.
Here is the what the web page says for active alert and if you go into NPM.
/6/2006 05:19 PM RSM4507.RSM4507.corp.cox.com GigabitEthernet7/5 · RSM-ORG Down Alert: Interface GigabitEthernet7/5 · RSM-ORG on RSM4507.RSM4507.corp.cox.com is Down.
Here is what was e-mailed out
Alert: Interface RSM4507.RSM4507.corp.cox.com-Port-channel53 · RSM-ORG on RSM4507.RSM4507.corp.cox.com is Up.
Any ideas as to why this happened? Am I overlooking something obvious?
Oh yes I did telnet into the switch and confirmed that the interface's are down so Orion NPM is telling correctly that the interface is down.
Thanks-GB
Find more posts tagged with
Accepted answers
All comments
ckore
Change ${Status} to ${OperStatus}
gbrance
Thanks. I have tested this and it seems to work. I am not sure why ${Status} doesn't work. The documentation for Orion seems to indicate that ${Status} will show current status of the interface.
Status
Current status of the interface (up, down, shutdown, etc.)
duncan_922
I had it too. It's a known issue that was fixed with the latest update 7.8.4.
From the release notes for 7.8.4: "Resolved issue where Alert macros for Interface and Volume properties would populate improperly. "
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
