Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Change View Sort Order
ldove
Hello All,
I have a need to change the sort order(ascending/descending) on one of my views. I am not a programmer of any type, but I couldn't find where to change how to do this. The particular one I am attempting to change is this "Broadband Interfaces with High Codeword Errors". It currently has 3 columns, no errors, corrected, uncorrectable. I want to change it from sorting on the no errors to the corrected, and in the ascending order.
-Lyle
Find more posts tagged with
Accepted answers
All comments
ldove
Bump. Anyone?
-Lyle
vhcato
Lyle,
Assuming you know where the resource files are on your server, you should be able to edit this particular resource file. I don't have the Broadband version of Orion, so I don't have that particular resource, but here's where you can change it in the "High Errors and Discards Today" resource. Perhaps you can locate the similar line in your resource and change it there.
This is actually one long line, but it will get wrapped on the forum.
SQLResource.SQL="SELECT Top 10 Nodes.NodeID, Nodes.VendorIcon, Nodes.Caption as NodeName, Nodes.GroupStatus, Interfaces.InterfaceID, Interfaces.InterfaceIcon, Interfaces.Caption, Interfaces.StatusLED, Interfaces.InErrorsToday, Interfaces.OutErrorsToday, Interfaces.InDiscardsToday, Interfaces.OutDiscardsToday FROM Interfaces INNER JOIN Nodes ON Interfaces.NodeID = Nodes.NodeID Where (Interfaces.InErrorsToday+Interfaces.OutErrorsToday+Interfaces.InDiscardsToday+Interfaces.OutDiscardsToday)>" & HighErrorsDiscards & " ORDER BY (Interfaces.InErrorsToday+Interfaces.OutErrorsToday+Interfaces.InDiscardsToday+Interfaces.OutDiscardsToday) Desc, Nodes.Caption, Interfaces.Caption "
See the "Desc" towards the end? Changing it to "Asc" will reverse to ascending.
Hope this helps...
Vic
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
