Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Exactly what devices are supported?
skaczkowski
All,
I can't for the life of me find a list of devices that Cirrus actually supports. In the tech docs it says it supports Cisco, HP, etc, but says nothing about what specific models of anything is supported..
Or is Cirrus just that smart and is able to deal with everything?
Thanks..
-Steve
Find more posts tagged with
Accepted answers
All comments
bleearg13
*Anything* that supports telnet and SSH can be put into Cirrus. Cirrus does have some pre-configured Device Templates for device manufacturers such as Cisco (IOS and CatOS), HP, Juniper (JUNOS and NetscreenOS), Foundry, and many others. It is not difficult to create a new device template, either, should you have a device that isn't one of the pre-configured manufacturers. I've even been successful in backing up config files from Linux servers.
Let's say that you have a NOC Monkey who can read through a list of devices, telnet into them, and do a 'show run' (or similar command). He then records those configurations in a text file. If you so wish, you can have this NOC Monkey alert you whenever he notices a change to any device config. That NOC Monkey is Cirrus. That's all it is from a configuration backup point of view. There are other features in Cirrus that go beyond a simple config backup utility, that from a security and policy perspective, might make it worth the purchase for your company.
EDIT: It looks like you already have Cirrus, according to your previous posts. Please excuse the above response if this isn't exactly what you were looking for.
skaczkowski
heheh...
Yes, we currently do own Cirrus and just wasn't quite sure of all the devices it could talk to..
-Steve
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
