Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Help! Bulk removal of nodes from node tree
jkelle
Ok, I'm a dope. There... got that out of the way upfront. I was not paying enough attention to what I was doing and accidently imported about 4,000 workstation nodes into my database. I want them out. I see no method for node deletion other than one-at-a-time. Anyone have any suggestions (other than RTFM... doin' that now, but in a real hurry to get this thing pared back down to just server and network elements)?
Thanks for any help in advance,
John
Find more posts tagged with
Accepted answers
All comments
Network_Guru
You can edit the DB directly to remove the nodes, but you must stop the Orion polling engine first, delete the nodes & then restart.
You could also just restore the DB from last night's back-up.
I have my DB scheduled to be backed up every night at 11:15PM to a flat file on my C drive.
At most, I will lose 24hrs of data.
The server is also backed up with Veritas nightly at 12:15AM.
-=Cheers=-
NG
Josh_Stephens
Like NG said, if you decide to delete the nodes directly from the database be sure to stop the Orion polling service(s) first and backup your database.
A good practice when doing bulk deletes like this is to run a "select" query first and then when you've verified the results change it to a "delete".
For instance, you might say:
Select * from Nodes
Where MachineType like '%Windows%'
If this query returns the nodes that you want to delete, just change the first part of the query:
Delete * from Nodes
Again, these are just examples so be sure to test this in your enviornment before actually deleting anything.
Happy hunting
Josh Stephens
SolarWinds R&D
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
