Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
NPM Version 8.0.18 database bloat still an issue
kesteele
I am still experiencing database bloat issues with the newest version. (8.0.18 at the time of this writing)
Admittedly, I monitor a large number of objects, (1431 network nodes and 332 interfaces) which was never a problem with version 5. The database bloat problem started with version 7 and still persists. My database grows about 100,000KB per day.
Version 8 includes a new feature to allow compacting the database at night during regularly scheduled maintenance. The compaction is not working for me.
I have my "nightly maintenance" scheduled to run at 8:00AM so I can be here to monitor it. I have the new "compact before maintenance" configured to run everyday. At 7:27AM the database was 1,170,468KB. At 8:00AM database maintenance ran (I verified that it ran by watching task manager and checking the log.) At about 8:20AM database maintenance finished so I checked the size and it was 1,178,696KB.
I then shutdown NPM and ran database maintenance manually. After compaction the size was 163,888KB.
I will contact Solarwinds support about this, but wanted to share my experiences to see if others were having the same issues.
Find more posts tagged with
Accepted answers
All comments
mjhamilton
Sounds like you should be really using Orion SLX for the number of devices you are monitoring...
However.. I have both Orion and EE8... not used the Monitoring tool in 8 but guess it is SQL based??
Before the automatic maintenance tools will work you must enable the SQL Server Agent else it will not kick off on its own....
Just a thought...
Martin J. Hamilton... lost in a sea of snmp...
jimin8r
I, too, am still experiencing the rapid growth of my database. Hopefully, they'll do something about it soon.
I also noticed that the new totals graphs, for % utilization are calculated incorrectly, showing half of the utilization.
kesteele
mjhamilton - to my knowledge the EE8 version is Access based.
jimin8r - I have not noticed the totals graphs being wrong. Where exactly is this?
mjhamilton
that being the case I think you should consider Orion on a SE SQL server.. this will prevent your issue...
It sounds like the EE version is for smaller networks with a few devices and low usage if it is access based...
Just my two pence worth...
jimin8r
kesteele, look under an interface, under Interface Traffic Charts and the newly added graphs at the bottom. One is Min/Max/Average Tx+Rx bps, the other is Min/Max/Average Tx+Rx Percent Utilization. Open the utilization chart, then compare it with the Min/Max/Average Percent Utilization chart that already existed.
kesteele
Ok, I see the new graph for Min/Max/Average Tx+Rx Percent Utilization is too low.
Have you reported this to SolarWinds? What did they say?
jimin8r
I sent them a screen print showing the two graphs side by side. Ryan, the tech support guy, emailed me later and said that he had forwarded it to the development team, and would let me know when they figured it out.
BTW, sorry to hijack your bloat post....
What have they said to you about the continuing bloat issue?
Bryan
I have contacted them about it also and was told to purchase Orion. They told me that with the number of nodes and interfaces that I was monitoring, that Toolsets wasn't designed for my situation. I think it would be nothing for Solarwinds to port NPM to SQL. The real draw to Orion is the web enabled monitoring. I use Big Brother for the quick and dirty remote view of the up and down status of my nodes, and NPM for trend and analysis. They really need to find a way to please the customer without trying to force everyone to spend an additional 8K for another product.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
rjenk
The database issue would not be one if the scheduled compact and repair would work. I have it scheduled to run twice a week on my system and it does not work. I still have to manually run it each week...so each Monday morning I shutdown NPM, compact and restart. I don't understand why they cannot get the scheduled compact to run.
Ray
kesteele
What I'm most upset about is the fact that Version 5 never had this issue. I could run Version 5 for 6 months before needing to compact the database.
I'm working with SolarWinds support to find out why the new "compact before maintenance" feature is not working. This is still just a band-aid though.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
