Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Groups and/or alert parenting
FormerMember
I would really like to see alert parenting, but I'd settle for device grouping. Let me explain...
Parenting: For each device, add the option to choose one or more other devices as a parent device. Then, in the alert configuration give an option to only trigger an alert for a device if it has at least one of its parents up.
Groups: I'd like the ability create device groups for use in alerting. Groups should be non-exclusive (i.e. a device could be in any number of groups). For example, I'd like to create both location and device type groups. A switch at a remote site might in a group for that site and a group for switches. I would want to be able to configure alerts (and alert suppressions) based on group memberships.
Possible for version 8? Is there an ETA and/or changelog for the next update?
-Rob
Find more posts tagged with
Accepted answers
All comments
iunderwo
You can kinda do this now with alert supression, but it's a horridly manual process that can grow beyond manageability if your network is of any respectable size.
// Ian Underwood - Service Management
// Level 3 Communications
FormerMember
I guess I should have added... is there a current way to do conditional paging without having a whole bunch of supressions? How are others handling this?
-Rob
pancamo
while we are on the subject....
Currently if I want to need setup a UP/DOWN alert for our email team, sqlserver team, network team, unix team, etc... I have to create a different alert for each team and select just their servers... with 1000's of servers this is impossible to maintain, and each time I add a server, I have to update the alerts
A QUICK SOLUTION FOR V7.5! ALLOW MACRO's in the TO field
If the TO field in the Alert Email Address allowed you to use a MACRO, then you could add a custom property "AlertEmail" and tag each node/interface with the correct contact. If the macro is blank, no email goes out.
This would allow you to create just ONE UP/DOWN alerts that covers all the groups. And you would not have to mess with the HUGE list of servers in the Alert window.
Simple change, HUGE benifit!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
