After upgrading to version 10.3.1 I received the following message on the "Finish" configuration wizard window.
There was no endpoint listening at net.tcp://xxx-xxx:17777/orion/core/businesslayer that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details.
I searched this site but found that this seems to be more of a general issue and that I should submit a ticket through support. But after looking through some windows logs there were a few events that stuck out..
Error starting plugin Orion
Access to Message Queuing system is denied.
Application: SolarWinds.BusinessLayerHost.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.ServiceModel.EndpointNotFoundException
Faulting application name: SolarWinds.BusinessLayerHost.exe, version: 2012.1.12.2305, time stamp: 0x500d30a6
I started with removing and adding message queuing and then rebooted the server. The web console came up with all my existing configurations. Haven't run through all of it but things seem to be fine. Maybe I did something wrong during the update or perhaps there is something that needs to be patched. Just wanted to pass this info on for anyone getting this error.
