Hi, Can anyone help me on Which table I can get these data in SDK. Device Performance, Device Fan, Power Supply.
@Sheetalkumar.Akkolli You should be able to find that data under the HardwareHealth section.
You can probably start with Orion.HardwareHealth.HardwareItem, or one of those, and build out from there.
Is this what you were looking for?
