You may experience issues like The web browser cannot establish an HTTPS connection.
Performed the following to overcome the issue.
- Log on to your main Orion server with administrator privileges.
- Run IIS Manager.
- Expand Sites in the left pane.
- Select the SolarWinds NetPerfMon site.
- Investigated the IIS settings regarding the certificate.
- Checked the certificate's validity (the certificate used on the Orion server could be a self-signed cert.).
- Exported the certificate from the main poller and imported it to the computer.
- The certificate error hasn't displayed after importing the certificate.
Please refer to the following article to learn more about SSL certificates in Orion.
support.solarwinds.com/.../Troubleshoot-issues-with-the-Orion-Web-Console-s-SSL-certificate
