So basically the title, cannot figure out how to do it no matter how much i try. There has got to be a way right?
Thank You.
On the node detail page, click on "List Resources". From there, you'll see a list of interfaces, volumes and other metrics related items, where you can pick the ones that interest you. If you simply need to remove interfaces, you can do so from the Manage Nodes page, by expanding your target node. you'll see what's currently monitored, and can check and delete the ones you don't want.
ok thanks that worked.
