Greetings:
We were considering to buy Aruba 6200F Layer 2+ switch JL728A#ABA 48 PORT and Layer 3 JL658A - 24 PORT and Layer 3 JL726A#ABA - 52 PORT. Looks like our budget request may not get approved.
Question 1:
Will Aruba Instant On 1930 48G Class4 PoE 4SFP/SFP+ 370W Switch (JL686A) meet the following requirements?
Forwarding bandwidth 104 Gbps
Switching capacity 176 Gbps
Forwarding Rate 130.95 Mpps
Stacking bandwidth 80 Gbps (Does it support stacking - if so how many units can be stacked)
DRAM size 1 GB
Flash size 512 MB
sFlow support Yes
NetFlow support Yes
DHCP Snooping Yes
10Gbps uplink ports
-Spanning Tree algorithm
-Broadcast limit
-IP Multicast Filtering
-VLAN support for Layer 2
-VLAN Trunking using IEEE 802.1p/q. (Calling VOIP phone 802.1p tags the traffic with
priority tag 6(voice) and the layer 2 switch should preserve that tag and take it to the
root router (layer 3 switch) which will convert it to layer 3 DSCP tags. The firewall also
should support the 802.1p/q and DSCP tags)
-LLDP support
-LACP support
-IPv6 Neighbor Discovery Protocol
FYI - here is the network layout in two buildings - connecting via VPN
Location 1:
1 - Layer 3 switch 24 Port 10Gbps
5 - Layer 2 switch 48 Port 1Gbps POE supporting 45 Ubiquiti U6-Wifi
10 - Layer 2 switch 48 port 1Gbps non-POE
Location 2:
1 - Layer 3 switch 24 port 10Gbps
3 - Layer 2 switch 24 port 1Gbps POE
1 - Layer 2 switch 48 port 1Gbps POE - Supporting 24 Ubiquiti U6-Wifi
1 - Layer 2 switch 48 port 1Gbps Non
Question 2:
What is the part numbers for
-Aruba Instant On 1930 48G Non POE
-Aruba Instant On 1930 24G POE (is POE power 370W, Fwdg bandwid 104G, Switch Capacty 176G, FWD Rate 130Mpps)
-Aruba Instant On 1930 24G Non POE
Question 3:
What will be Layer 3 equivalent in 1930 series for 6200F JL658A - 24 PORT and JL726A#ABA - 52 PORT
Question 4:
What kind of central management is being offered by HPE for 1930 series switches?
Thanks!
