I want to monitor mount point which is located in Local Drive (D) on SQL database server. The Orion Database is located under the mount point.
We are currently using NPM, NCM, NTA module with Orion 2020.2.6 version. I tried using list resources and getting all drives with mounted drives too. However, what about the mount points which are located inside the local drives?
Can anyone suggest please?
