I want to uninstall the SAM product, I was installing the product, but due to some issue, it's shown an error to me.
So, I want to uninstall it and re-install the same once again. So, Please tell me, how can I uninstall the SAM products?
Have you installed it in conjunction with other SolarWinds modules or is it a standalone SAM installation ?
@cheryl1 has pointed you in the right direction, go through that link.
But with the kind of experience I have with a multi module setup, its not always easy to uninstall SolarWinds modules, its best for you to raise a SolarWinds support case. If I am not wrong for some customers they did provide custom uninstall scripts to uninstall modules, but then it again depends on case to case basis, this is not something that SolarWinds support does on a regular basis.
But end of the day I am not very confident or comfortable in stating it will be a clean uninstall.
Which version is your environment on?
Check out this article which takes you step-by-step through uninstalling SAM on version 2020.2.6 or earlier. If your version is later than 2020.2.6, I suggest you contact support to make sure the process is the same.
https://documentation.solarwinds.com/en/success_center/sam/content/sam-install-uninstall.htm
Any additional questions, you should probably reach out to support so they can understand your specific environment and make the appropriate recommendations.
I don't know. Can you please tell me how to find the product version?
When logged in right at the bottom off the webpage it will say which modules you have and the version number
While opening the Solarwinds web console, it's showing an error. Because of this, I am unable to check the version. I tried to uninstall manually using the control panel as well as tried to delete Solarwinds related folder from the C drive. But few folders, I am unable to delete as well few components I am unable to uninstall using a control panel.
In the command line, run the following command:
'path to exe'\SolarWinds.Orion.Installer.exe -uninstall
</code></p><p><code>---I Tried to run above command to uninstall all the components, but it's not working.
I am new to this product, so I don't know about most of the components. I am trying to install this product for the 1st time in my LAB to understand the product and its working style. So, I downloaded the offline installer like "Solarwinds-SAM-2023.1.0-OfflineInstaller" and try to download this, following the given steps. But in the end, I receive failed installation msg, but so many components are populated in the control panel. But the product is not opening.
There are 3 reasons for uninstalling SAM.
-In the SolarWinds Platform Web Console, select Settings > All Settings and click License Manager.-In the License Manager, select the SAM license to remove.-Click Deactivate to remove the SAM license activation and server assignment. With the license deactivated, it is parked, or available but unused.
Apart from this if you want to learn something new then salesforce marketing cloud training is to assist both professionals and beginners with fundamental and advanced Salesforce topics.
I'm sorry I missed your reply. Since this is the SCP forum, I don't watch it as closely as I do the Classroom forum. I agree that if you are having issues, please raise a support ticket. Ease of uninstall is something that the product team has continued to work on and improve. That's not to say that there isn't an issue sometimes, particularly from influences in the environment. I hope support was able to assist you!
If you're looking to uninstall SAM (Software Asset Management) products, the process can vary depending on the specific product and your operating system. Here's a general guide that you can follow:
For Windows:
Control Panel:
Find the SAM Product:
Uninstall:
Follow the Uninstallation Wizard:
For Mac:
Finder:
Applications:
Locate the SAM Product:
Move to Trash:
Empty Trash:
For Linux:
Terminal:
Navigate to Installation Directory:
Uninstall Script:
And if you ever need to express your tech triumphs or seek a bit of encouragement, Flower Delivery McAllen TX could add a touch of positivity to your day! If you have more questions or need further assistance, feel free to let me know.
To uninstall a software product like SAM, you can typically follow these general steps:
Use the Uninstall Utility (if available): Some software comes with an uninstall utility. Check the program folder in the Start menu or the installation directory for an uninstaller executable.
Windows Control Panel:
Settings App (Windows 10 and newer):
Command Line (Optional):
After uninstalling, you can then proceed with reinstalling the SAM product. Remember to check the official documentation for the SAM product for any specific uninstallation instructions.
Regarding the naked URL 'https://pdfdownload.pk', it's unclear how it relates to the discussion about uninstalling SAM. If there's a connection or if you have a specific question about the URL, please provide more context or ask a relevant question.
Correct. A support ticket is probably a good idea if you're not completely sure. I do know in recent years we've released several improvements to make an uninstall easier but sometimes as with uninstalling any complex software, there are some cleanup steps that have to be done.
Also, and I can't stress this enough BACK UP YOUR DATABASES BEFORE PERFORMING ANY CHANGES TO YOUR INSTALLATION (yes, the all caps is intentional)
To uninstall the SAM product, go to your system's control panel, locate "Programs" or "Add/Remove Programs," find the SAM product in the list, and select "Uninstall." Follow on-screen prompts to complete the process. Once done, you can reinstall the product. For professional tech assistance, consider reaching out to support. #ServiciosEnfermeríaGuatemala
Goodgood amazing .i have some extra information visit. patio covers
