I want to create a Warless heat map for a Cisco 9800-80 WLC but the AP's are not showing up in network Atles. has anyone got the cisco 9800 wlc to work with NPM
I got the wireless heat map working but now the wireless client location Poller Scan Result is Not a match. how do I know what OIDs are missing so i can get them
https://support.solarwinds.com/SuccessCenter/s/article/Wireless-OIDs-polled-in-NPM?language=en_US
support.solarwinds.com/.../What-object-IDs-OIDs-does-NPM-poll-for-interface-information
thanks for the OID's list.so should I create a costume Poller? and which OID's are for client location?
It seems that mine started working with a recent update. Do you still have this problem?
Hey @Bashar.aleisa just an FYI on heatmaps in Network Atlas.These are not "live" maps but rather a one shot and done. So when you generate the heatmap it is accurate (as it can be) at that point in time. It doesn't constantly update in real time, or even near real time, to show the current state of play.
Understood that they are not live maps. My big issue with the maps is that you can have wireless client location turned on. This works but does not update every 5 minutes. My current heat map states "Last Client Calculation: 4:17 PM (Updated every 5 minutes)" and is showing the data from 17 hours ago.... not five minutes as stated. Not sure exactly how to get the client calculation to actually update every 5 minutes but it would be nice to know.
As NA is under a deprecation notice then there will be no more development on that side - of that we can be certain. Sadly Orion Maps doesn't have heatmaps yet but one can hope that they will actually be fit for purpose if and when.
