This is the code i'm try to add AlertNote to this code
SELECT [AlertObjects].AlertConfigurations.Name AS [Name]
,'/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:' + TOSTRING([AlertObjects].AlertObjectID) AS [Name_URL]
,[AlertObjects].AlertConfigurations.Severity AS [Name_Severity]
,[AlertObjects].EntityCaption AS [Object]
,[AlertObjects].Node.Status AS [Object_Status]
,[AlertObjects].EntitYDetailsUrl AS [Object_URL]
,[AlertObjects].Node.CustomProperties.Customer AS [Customer]
,[AlertObjects].Node.CustomProperties.City AS [City]
,[ActiveAlerts].AlertObjects.AlertNote AS [Alert Note]
,CASE
WHEN [AlertObjects].RelatedNodeCaption = EntityCaption
THEN '[Self]'
ELSE [AlertObjects].RelatedNodeCaption
END AS [Related Node]
,[AlertObjects].RelatedNodeDetailsURL AS [Related Node_URL]
,[AlertObjects].Node.Status AS [Related Node_Status]
,TOSTRING(TOLOCAL([AlertObjects].AlertActive.TriggeredDateTime)) AS [Time]
,TOLOCAL([AlertObjects].AlertActive.TriggeredDateTime) AS [Time_SORT]
,CASE
WHEN MINUTEDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) > 1440 -- More than 1 Day (1440 minutes)
THEN (TOSTRING(ROUND(MINUTEDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) / 1440.0, 1)) + ' Days')
WHEN MINUTEDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) > 60 -- More than 1 Hour (60 minutes)
THEN (TOSTRING(ROUND(MINUTEDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) / 60.0, 1)) + ' Hours')
ELSE (TOSTRING(MINUTEDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE())) + ' Minutes')
END AS [Active]
,CASE
WHEN DayDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) > 7 -- More than 7 Day (1440 minutes)
THEN 14
WHEN DayDIFF([AlertObjects].AlertActive.TriggeredDateTime, GETUTCDATE()) < 2 -- Less than 2 Day
THEN 1
ELSE 3
END AS [ActiveIcon]
, CASE
WHEN [AlertObjects].AlertActive.Acknowledged IS NULL
THEN 'Unacknowledged'
ELSE CONCAT([AlertObjects].AlertActive.AcknowledgedBy, ' (', TOLOCAL([AlertObjects].AlertActive.AcknowledgedDateTime), ')')
END AS [Acknowledge]
, CASE
THEN CONCAT('/Orion/NetPerfMon/AckAlert.aspx?AlertDefID=', [AlertObjects].AlertObjectID)
ELSE CONCAT('/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:', [AlertObjects].AlertObjectID)
END AS [Acknowledge_URL]
FROM Orion.AlertObjects AS [AlertObjects]
-- Mandatory JOINS needed if you want to filter via nodes custom properties
--LEFT JOIN Orion.NodesCustomProperties AS [NodeCP]
-- ON [AlertObjects].RelatedNodeID = NodeCP.NodeID
--LEFT JOIN Orion.Nodes AS [Nodes]
-- ON [AlertObjects].RelatedNodeID = Nodes.NodeID
WHERE [AlertObjects].AlertActive.AlertActiveID > 0
-- AND [AlertObjects].Node.CustomProperties.[CP_Name] = 'CP_Value'
GROUP BY [AlertObjects].AlertActive.AlertActiveID,
FROM [ActiveAlerts].AlertObjects.AlertNote AS [Alert Note]
